Pages: [1]   Go Down
Author Topic: Resistor question  (Read 1667 times)
glynnw
Jr. Member
Offline Offline
View Profile
« on: October 26, 2009, 09:05:59 AM »
When building crossovers I occassionally need a value that is only available as an inexpensive resistor, and I would prefer to use something like the Mills resistors.  From a sonic standpoint, am I better off using 1 inexpensive resistor (like some of the Dayton resistors  from PartSEXpress) or combining a couple of Mills resistors to get the value I need?
Logged
PC based music server using XXHighEnd software, Wavelength Brick V3 24/96 DAC, Bent Audio Tap-X Passive preamp, 300B Paramounts, Basszilla Platinum Mk II speakers, Bag End 18" subwoofers, Van den Hull spkr cable, handmade siver interconnects.
Doc B.
Administrator
Hero Member
Online Online
View Profile WWW
« Reply #1 on: October 26, 2009, 09:17:28 AM »
There shouldn't be any penalty in combining a couple of Mills resistors, and they will probably sound a little better than the sand cast ones. The Ohmite wirewounds sound nice too.
Logged
Hero Member
Offline Offline
View Profile
« Reply #2 on: October 26, 2009, 09:55:20 AM »
Do be aware that some of the cheap sand cast resistors are actually wirewound in the smaller values, but metal oxide in the larger values. You have to get the data sheet to figure this out. The wirewound ones are not bad, but metal oxide has a bad reputation sonically.
Logged
glynnw
Jr. Member
Offline Offline
View Profile
« Reply #3 on: October 26, 2009, 12:53:24 PM »
Thanks. I have some Mills on order and will combine 2 of them to get the value I want.
Logged
Wardsweb
Full Member
Offline Offline
View Profile WWW
« Reply #4 on: October 26, 2009, 01:12:14 PM »
Good advice all around. I've always liked Allen Bradley carbon comp resistors and was lucky enough to get a closing electronics repair shops entire inventory of resistors, caps, pots, switches, IC's, diodes, transistors, LEDs, knobs, etc... Let me know if you ever break one of the plastics keys on a Mini Moog, need a pinch roller for your Teac or need a lighted switch for a Tascam.
Logged
Pages: [1]   Go Up
Jump to:
