Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News
: Now taking orders for the Tode, Bottlehead's new guitar amp kit!
Calendar
Bottlehead Kits
Stereomour
AC Voltage Reading Problem
Pages: [
Author
Topic: AC Voltage Reading Problem (Read 870 times)
astroimage2002
Newbie
Offline
October 23, 2010, 12:45:34 PM »
Hi All,
We now have the correct resistance on the terminals. What we are seeing now is an issue with the AC. The amp has been configured for 45's NOT 2a3's. Here are the AC voltage issues we are seeing:
Pad Expected Actual
HV+ 350 434
Terminal Expected Actual
1 340 436
4 0 430
5 57 0
11 57 0
12 0 430
16 57 0
20 57 0
A1 57 0
A2 340 433
A3 0 434
A4 57 0
C1 57 0
C2 340 433
C3 0 433
C4 60 0
PC Board checks fine.... I should also let you know that I have 2a3's mounted in the amp when checking the voltages.
HELP!!!
Brian
Last Edit: October 23, 2010, 12:57:12 PM by astroimage2002
Logged
Hero Member
Offline
Re: AC Voltage Reading Problem
Reply #1 on:
October 23, 2010, 04:29:28 PM »
Very disturbing!
The first explanation that occurs to me is that you may have installed the 4-pin tubes or sockets rotated 180 degrees.
I just now checked page 32 of the manual, and sure enough there is no warning or caution about orienting the socket correctly. We'll have to fix that! Looking at the socket, you will see that two of the holes are slightly larger, these are pins 1 and 4. (They are larger because they carry the filament current, which is much greater than the other connections.) They should be the two holes closes to the hum-balance pot. On page 46 of the manual you can see where the filament power is wired to those pins, and on page 63 the hum pot is connected through the 22 ohm cement resistors. When the tube is inserted into the socket, the larger (fatter) pins should go into those holes. Occasionally someone will force the tube into the socket incorrectly - it is possible, though fairly difficult. I suppose this is one of the reasons that later tubes have a more unequivocal orientation!
If you have reversed the socket, you'll have to fix that. You'll want some solder-sucking copper braid to get the wires off the pins; other than that it should be easy. If you've inserted the tubes incorrectly, the small socket pin connectors may be stretched out - make sure you have secure connections before testing again. If the socket is too badly damaged to provide reliable connections, Eileen can fix you up with replacements.
If neither of these is the problem, then we'll have to re-visit the situation, and perhaps ask for a few more measurements.
Logged
astroimage2002
Newbie
Offline
Reply #2 on:
October 23, 2010, 04:50:40 PM »
Hi Paul,
I thank you for the information! As you suspected I have the sockets 180 degrees out of rotation. Soldering iron is warming up... Copper is at the ready... Hope that I don't need to bug Eileen (what a sweet heart she is!)
I'll report back after they are rotated and re-soldered. Fingers crossed
Logged
astroimage2002
Newbie
Offline
Reply #3 on:
October 23, 2010, 06:40:28 PM »
Paul,
You nailed it. Tube sockets have been rotated 180 degrees and the amp is now alive.
Many thanks!
Brian
Logged
jtkarma
Newbie
Offline
Reply #4 on:
October 26, 2010, 10:47:59 PM »
Hehehehe.
Interesting thread.
What a great place the Bottlehead Forum is.
Please post your results once your sort out your issues. Love to hear what your thoughts are on the amp.
Logged
astroimage2002
Newbie
Offline
Reply #5 on:
October 27, 2010, 02:49:09 AM »
jtkarma,
The amp was up and going in just over two hours after Paul's post. Once Paul Genius Joppa figured out where I messed up it was just a matter of flippin' the tube sockets around I was off to the races!
As for how it sounds... I will do so in the coming weeks.
Brian
Logged
Pages: [
Jump to:
Please select a destination:
General Category
=> Forum Rules
=> General Discussion
=> Bottlehead Special Deals
=> VALVE archive
=> Technical topics
=> Tech Tools
=> All things MagneQuest
=> Grainger's Corner
Bottlehead Kits
=> Gallery
=> Quickie
=> Crack
=> Smack
=> Foreplay III
=> Seduction
===> Seduction Tape Head Preamp
=> Eros Phono
=> Eros Tape
=> S.E.X. Kit
=> Stereomour
=> Paramount
=> Bottlehead Power Cord Kit
=> Technics Tape Path Kit
=> Tode
=> Legacy Products
Bottlehead Finished Products
=> Tube Phono
=> Tube Repro
Other Gear
=> Speakers
=> Headphones
=> Phono
=> Digital
=> Reel to Reel Tape
Loading...
