Pages: [1]   Go Down
Author Topic: First time soldering advice  (Read 730 times)
denti alligator
Full Member
Offline Offline
View Profile
« on: December 04, 2010, 02:18:54 PM »
I've never soldered before and have been looking for how-to's online. In building the SEX will I mainly be soldering wires to terminals? If so, is this the best way to do it? Do I twist the wires together first? How far do I thread the wire through the terminal before soldering?
I bought some basic ring terminals and will be practicing with old speaker wire. Any extra advice would be appreciated.
Logged
- Sam
"Life without music would be a mistake." - Friedrich Nietzsche
Rega P3-24 (Ortofon 2M Red) / Seduction w/ C4S / Denon 2930CI (CD/SACD/DVD-A) / S.E.X. Amp w/ C4S / Klipsch Forte II / Sennheiser HD-600s
JC
Sr. Member
Offline Offline
View Profile
« Reply #1 on: December 04, 2010, 02:48:12 PM »
Perhaps the most important point to take away from the video is that you heat the joint, then let the joint melt the solder.
In your kit, you will mostly be attaching non-stranded wires and component leads to terminals.  Many terminals will have more than one wire or lead attached, so make sure the instructions specifically tell you to solder a terminal before you actually solder it!
If you are attaching an insulated wire, you will generally be instructed to strip it about 1/4".  Then, you will feed it through the eye of the terminal and bend it to crimp it onto the terminal.  It is important to make a good solid mechanical connection of the wire or lead to the terminal prior to soldering it.  For one thing, a good mechanical connection prevents the wire from moving around on you while soldering.  Such movement leads to "cold" solder joints.
As I have mentioned in the past, Radio Shack carries (or, at least, used to carry) 5-lug terminal strips very similar to the ones used in the kits.  A few of these and some cheap resistors are good for practice.  Just screw the terminal strips down to a scrap of wood, and have at it!
BTW, if the video guy tells you he is going to be taking extreme close-ups of your hands, it's always good to pop for a manicure!
« Last Edit: December 04, 2010, 06:06:24 PM by JC » Logged
Jim C.
Grainger49
Hero Member
Offline Offline
Audio Cheapskate
View Profile
« Reply #2 on: December 04, 2010, 06:24:34 PM »
Naah, it would be the first manicure I ever got.  But please clean under your fingernails!
Now that I have seen the video, this guy chews his fingernails and the do look ragged.
« Last Edit: December 04, 2010, 06:27:15 PM by Grainger49 » Logged
Grainger Morrison,
2wo
Sr. Member
Offline Offline
What? you want to look at my ugly mug?
View Profile
« Reply #3 on: December 04, 2010, 08:16:35 PM »
Did you see that stand, with the alligator clips, that he was using? it's called a third hand. If you see one of those, grab it. it is as handy as looks.
Radio Shack used to have them...John
Logged
John Scanlon
Grainger49
Hero Member
Offline Offline
Audio Cheapskate
View Profile
« Reply #4 on: December 05, 2010, 05:12:14 AM »
Harbor Freight sells the third hand for about $6.  The key with HF is that you only buy on sale because many things can be had for almost half.  So $3 or $4 is what they sell it for regularly.
I wouldn't buy a soldering iron, solder or a meter there but they have some good hand tools.  In particular they have small needle nose pliers, diagonal cutters etc. that spring open for $10 (Item #94931).
Logged
Grainger Morrison,
Pages: [1]   Go Up
Jump to:
