Bottlehead Forum Bottlehead Forum
Welcome, Guest. Please login or register.
Login with username, password and session length
News: Now taking orders for the Tode, Bottlehead's new guitar amp kit!
   Home   Help Search Calendar Login Register
Pages: [1]   Go Down
Author Topic: Does anyone use solder fume/smoke absorbers?  (Read 1989 times)
rif
Newbie
Offline Offline
View Profile
« on: February 14, 2011, 06:39:10 PM »
I didn't see these on any 'tool wish lists' here or elsewhere, so probably no one does.  But at face value, it would seem like a good use of $50. I'm very tempted to get one even if they don't do much since I'm paranoid about this type of thing and I'll be soldering in a spare bedroom/office with the windows closed.
There's one by Weller (WSA350). Other companies make similar looking ones.
Hakko makes one that seems a little different -- you can use it in two positions. But it costs twice as much.
Here's what they look like:
Hakko
Weller
Logged
Maxwell_E
Full Member
Offline Offline
Max Tomlinson
View Profile
« Reply #1 on: February 14, 2011, 07:09:17 PM »
The one we have in the lab is just a computer fan in a little aluminum case. I haven't seen anyone on the lab use it in two years, and my boss moved it out there from his office because he never uses it. If you were worried about safety, I recommend safety glasses. Nothing like a solder blob in/around your eye to make you lean back real quick.
Logged
Grainger49
Hero Member
Offline Offline
Audio Cheapskate
View Profile
« Reply #2 on: February 15, 2011, 05:13:26 AM »
There have been some discussions of this item here or the old board.  In my tool thread (http://www.bottlehead.com/smf/index.php/topic,173.msg863.html#msg863) I mention a fan for blowing away the smoke.  I have it mounted 3' away so it doesn't cool the solder joint.  I will edit my thread's OP and put this as an alternative.
« Last Edit: February 17, 2011, 05:38:18 AM by Grainger49 » Logged
Grainger Morrison,
Mozzie quote: Sacred cows make the best hamburgers!
Remember, YOU are the only one who needs to be happy with the sound of your system.
Eros (Mods Have Begun!)/FP-2/Paramour 1/upgrades to all - PS Audio Regenerator, Triangle Zerius Speakers, BA Sub
dbishopbliss
Administrator
Full Member
Offline Offline
View Profile
« Reply #3 on: February 15, 2011, 07:47:58 AM »
I had the same concern, but encountered sticker shock when looking for a fume absorber.  There were some DIY versions that I saw, then I came across the Febreze Odor Removal Appliance.  It uses a carbon filter for odor removal, which is the same type of filter that the Hakko and Weller products use.  I'm not sure if its really as good, but it seems to work for the limited amount of time I am soldering.
It is meant to plug into a wall, I just attach it to an extension cord and place it next to my project.
Logged
David B Bliss
Bottlehead: Foreplay I, Foreplay III, Paramour I w/Iron Upgrade, S.E.X. w/Iron Upgrade
Speakers: FE127E Metronomes, Jim Griffin Jordan/Aurum Cantus Monitors, ART Arrays
Other: Lightspeed Attenuator, "My Ref" Rev C Amps, Lampucera DAC
sl-15
Newbie
Offline Offline
View Profile
« Reply #4 on: February 15, 2011, 10:47:35 PM »
hi rif,
i had the same question a few years back when i started. see the link to this little thread:
http://db.AudioAsylum.com/mhtml/m.html?forum=bottlehead&n=131579
i bought the weller kind absorber back then. i think it could be a little stronger suction wise but if you put it close enough to your stuff beeing soldered it works alright. it does filter some of the nasty smell and keeps the fume out of your eyes. i found soldering a little more relaxing that way rather then sitting there and holding your breath trying to not inhale the fumes. also if you look at those carbon filters after a while you are glad this kind of residue is not settling somewhere in your room. so in my opinion it is worth the investment.
« Last Edit: February 16, 2011, 07:28:03 AM by dbishopbliss » Logged
stefan hampel
ortofon sl-15 with step-up, technics sl-1200mkII, seduction c4s, foreplayIII, marantz pm 7000 and hafler pro1200, b&w 602 S3 bookshelf
Grainger49
Hero Member
Offline Offline
Audio Cheapskate
View Profile
« Reply #5 on: February 16, 2011, 05:09:54 AM »
Stephan,
That is the thread I was thinking about.
« Last Edit: February 17, 2011, 05:35:46 AM by Grainger49 » Logged
Grainger Morrison,
HF9
Full Member
Offline Offline
Zynsonix.com
View Profile WWW
« Reply #6 on: February 17, 2011, 09:44:47 PM »
It seems like it would be worth the investment, but scrounging up $100 for a glorified fan and filter is a little difficult to do Tongue
Logged
sl-15
Newbie
Offline Offline
View Profile
« Reply #7 on: February 17, 2011, 10:53:45 PM »
true $100 seems too much. i got mine back then used for $40 on ebay.
Logged
stefan hampel
HF9
Full Member
Offline Offline
Zynsonix.com
View Profile WWW
« Reply #8 on: March 01, 2011, 01:29:12 PM »
I opted to go ahead and get one, figured it couldn't hurt. I got the Inland Fumetrap. It's relatively simple and doesn't waste too much space on the desk.
Logged
sl-15
Newbie
Offline Offline
View Profile
« Reply #9 on: March 15, 2011, 09:24:22 PM »
hi HF9,
have you used your new fumetrap yet. i am curious what you think and if it is having good suction power. i recently used mine again and thought it was working rather poorly. if you do not put it right in front of the fumes it does not work too well. maybe your brand/design works better?
thanks, stefan
Logged
stefan hampel
pro_crip
Full Member
Offline Offline
View Profile
« Reply #10 on: March 16, 2011, 02:58:32 AM »
I like solder fumes Smiley Seriously though, I've read that those aren't lead fumes, solder melts at too low a temp for vaporization (doesn't reach boiling point).  Thanks for listening.
Rich
Logged
Richard J Feldman
Tune down, smoke up
Grainger49
Hero Member
Offline Offline
Audio Cheapskate
View Profile
« Reply #11 on: March 16, 2011, 04:56:15 AM »
Back in the linked thread, above, I recalled that when I was modding some Dynaco equipment back in the 90s I got horrible headaches, not as bad as migraines, but bad ones.  Solder fume removal has cured headaches for me.  YMMV.
Logged
Grainger Morrison,
HF9
Full Member
Offline Offline
Zynsonix.com
View Profile WWW
« Reply #12 on: March 16, 2011, 10:40:23 AM »
It seems to work okay within about a foot. I find myself not using it as much as I thought as it's a little loud and interferes with whatever music I'm listening to.
Logged
Hero Member
Offline Offline
View Profile
« Reply #13 on: March 16, 2011, 12:15:13 PM »
Rich
That's what I've heard as well. It's mostly flux fumes. It is very bad for asthma, in fact capable of causing it if you breathe the stuff all day every day.
Logged
Pages: [1]   Go Up
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.10 | SMF © 2006-2009, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
