Pages: [1]   Go Down
Author Topic: LED Indicator  (Read 799 times)
Dr. Toobz
Sr. Member
Offline Offline
BH: So easy, even a shrink can do it.
View Profile
« on: June 06, 2011, 07:11:54 PM »
With the tube shields on, it's hard to tell when the Seduction is running. Would there be any issue with sticking a common orange or red LED in one of the holes meant for the Hammond box (not needed in my case) and then running the LED, in series with a 1000 ohm resistor, in parallel with the two 6.3V tube heaters? I'm assuming this would only add about 20mA of current to the winding, depending on the LED?
Logged
-Angelo
Hero Member
Offline Offline
View Profile
« Reply #1 on: June 06, 2011, 08:57:45 PM »
Should be no problem.
Logged
debk
Full Member
Offline Offline
View Profile
« Reply #2 on: June 07, 2011, 01:08:42 AM »
I did it with a blue LED.  worked great
Debra
Logged
Debra K
2CH system:
Eros Phono Stage
Extended Foreplay III
Tubelab SE Amp 300b
Music Hall MMF 5.1, Goldring G1042
Emotiva ERC-1 CD
Emotiva XDA-1 DAC
Cambridge Audio iD100 Digital iPod Dock
DIY Fostex 206eN speakers
Pfenning
Jr. Member
Offline Offline
View Profile WWW
« Reply #3 on: January 19, 2012, 03:36:22 PM »
Can someone give me a little instruction how to wire this in? I get the resistor and LED part, but where is the best place to tie it in?
Thanks, Pfenning
Logged
Pfenning
Paramour 1's with c4s and iron upgrade, Foreplay II, Seduction with c4s, Crack and Foreplay III waiting to be built, DIY turntable with Rega RB250 arm with Incognito wiring, Oppo DVD, Pi Stage 4's and DIY subs
porcupunctis
Full Member
Offline Offline
0D3
View Profile
« Reply #4 on: January 19, 2012, 06:20:03 PM »
Would there be any problem using a 120V indicator lamp?  That should be easy to wire and wouldn't require a resistor to drop the voltage off the mains.  I'm pretty sure I have a few out in the garage in one of my bins full of parts.
Logged
Randall Massey
Teacher of Mathematics
Grainger49
Hero Member
Offline Offline
Audio Cheapskate
View Profile
« Reply #5 on: January 20, 2012, 02:59:03 AM »
An incandescent light, not neon, adds no noise.  Can you find one at 120V?
Logged
Grainger Morrison,
Pfenning
Jr. Member
Offline Offline
View Profile WWW
« Reply #6 on: January 27, 2012, 08:48:33 PM »
Found a 120 vac lamp at the Rat Shack in a 2 pack for $4. Had to drill out one of the existing unused mounting holes to 1/4" and slipped it right in. It worked really good, I might add one to all my Bottlehead gear. It's easier for my kids to see if it's on or off. I also bought some 3/16" black plastic hole plugs for the other 3 holes. Sounds silly, but it gave it more of a finished look.
Logged
Pfenning
Pages: [1]   Go Up
Jump to:
