Pages: [1]   Go Down
Author Topic: Tape Deck Modifications  (Read 1402 times)
mchurch
Jr. Member
Offline Offline
View Profile
« on: July 16, 2011, 07:21:53 AM »
I am a newbie to this area but I wanted to know if there is any guidance information available from the members as to how modify the tape deck to use the EROS. I am assuming that I will have to re-wire the heads to go direct to the input of the EROS. It appears that the only mods will be to playback so can I still use the record functions. Any information would be appreciated. My equipment is currently a Revox B77 and a Teac X1000R .
Mike
Logged
Hero Member
Offline Offline
View Profile
« Reply #1 on: July 16, 2011, 12:27:22 PM »
The Eros is derived from the Tube Repro high-end design, and has similar input capabilities. You can see more at
http://www.bottlehead.com/store.php?crn=223&rn=437&action=show_detail
From that page:
"The Tube Repro is designed as a versatile tape head preamp that works well with medium to high inductance playback heads. It has been developed from the start as the perfect match to Flux Magnetics Extended Response playback heads. ... Most any modern tape recorder, once modified to direct output from the playback heads, will work with the Repro."
Tape heads, like phono cartridges, come in a variety of impedance and voltage levels; any tube amp will be designed for medium to high output heads. Head sensitivity is rated by impedance, and 200 to 700mH is a typical range for tube preamps. It's best to be sure your tape heads are compatible before re-wiring you tape deck (!)
Logged
Doc B.
Administrator
Hero Member
Offline Offline
View Profile WWW
« Reply #2 on: July 17, 2011, 07:00:59 AM »
A B77 will work fine. Not 100% sure about the TEAC, but there are very few tape decks that use low impedance heads, so it's probably a safe bet that it will work fine.
Logged
mchurch
Jr. Member
Offline Offline
View Profile
« Reply #3 on: July 17, 2011, 08:11:13 AM »
Thanks Paul & Doc;
I will look into the impedance of the Teac heads to see where they fall. I am just trying to formulate a build plan before I start to modify one or both of the decks. I just wasn't sure how the tape head amps would be connected to the heads. I want to keep the number of connections to the minimum so I might hardwire the heads to connectors the would plug into the playback amp.
Cheers
Mike
Logged
Pages: [1]   Go Up
Jump to:
