Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News
: Now taking orders for the Tode, Bottlehead's new guitar amp kit!
Calendar
Bottlehead Kits
S.E.X. Kit
SEX amp 2.1 4/8/16 or 32 ohms?
Pages: [
Author
Topic: SEX amp 2.1 4/8/16 or 32 ohms? (Read 606 times)
Todd R
Jr. Member
Offline
July 22, 2011, 07:30:11 PM »
Hi,
Just saw the new amp that's coming out. Pretty sure I'll be getting one, but was curious about the output wiring options of 4/8/16 or 32 ohms.
That wouldn't really concern the headphones, it would be more of an option for the speakers you want to use, correct?
Logged
mrarroyo
Jr. Member
Online
Re: SEX amp 2.1 4/8/16 or 32 ohms?
Reply #1 on:
July 23, 2011, 05:02:17 AM »
Could the speaker outs be used to drive the AKG K1000 or the HiFiMAN HE-6 cans? Thanks.
Logged
Grainger49
Hero Member
Offline
Audio Cheapskate
Reply #2 on:
July 23, 2011, 07:40:52 AM »
The speaker outputs are the same tap as the headphone output. The headphone jack uses a series dropping resistor. I'm thinking there might be a problem using a different transformer tap for the headphones than the speakers, might be OK.
Regardless, it is safe changing or eliminating the series resistor at the headphone jack.
Logged
Grainger Morrison,
Todd R
Jr. Member
Offline
Reply #3 on:
July 23, 2011, 07:47:56 AM »
So if you have 600 ohm headphones and a 32 ohm pair, what taps would you use so both pair sound good?
Logged
Doc B.
Administrator
Hero Member
Offline
Reply #4 on:
July 23, 2011, 08:12:31 AM »
You can only wire up one impedance setting at a time. We will have little under-chassis upgrade boards with switches that will allow setting output impedance without having to disconnect anything, but that will still produce only one output impedance at a time. Yes, in general the various taps are for loads that are a the close match, so 4,8 and 16 are primarily for speakers and the oddball phones ( I think there are some IEMs) that are down in that range. For headphones from 32 ohms on up to 600 ohms the 32 ohm tap makes the most sense. I don't know if the K1000s would be driven adequately, but I would try the 32 ohm tap to find out.
Logged
Todd R
Jr. Member
Offline
Reply #5 on:
July 23, 2011, 11:50:18 AM »
Thanks Doc,
Apart from it's other capabilities, would you consider the new SEX amp an upgrade over the Crack/Speedball when using something in the Sennheiser 580/600/650 family?
Logged
Doc B.
Administrator
Hero Member
Offline
Reply #6 on:
July 23, 2011, 12:06:56 PM »
Here's what I think about the best headphone match to the various amps:
http://www.bottlehead.com/et/whichheadphoneamp.htm
Logged
Pages: [
Jump to:
Please select a destination:
General Category
=> Forum Rules
=> General Discussion
=> Bottlehead Special Deals
=> VALVE archive
=> Technical topics
=> Tech Tools
=> All things MagneQuest
=> Grainger's Corner
Bottlehead Kits
=> Gallery
=> Quickie
=> Crack
=> Smack
=> Foreplay III
=> Seduction
===> Seduction Tape Head Preamp
=> Eros Phono
=> Eros Tape
=> S.E.X. Kit
=> Stereomour
=> Paramount
=> Bottlehead Power Cord Kit
=> Technics Tape Path Kit
=> Tode
=> Legacy Products
Bottlehead Finished Products
=> Tube Phono
=> Tube Repro
Other Gear
=> Speakers
=> Headphones
=> Phono
=> Digital
=> Reel to Reel Tape
Loading...
