Hi just saw this and this is a reply to another question:
I commissioned this model originally, and it was confusing when I first saw it, but it was designed as an 8k winding that they put a CT in. So for parafeed pin 1-4 is 8K It is similar to all their other line output transformers in that it is push pull, but can be used as parafeed out. They stated it should have about 15h inductance for what it is worth. I have 10, but still have been to lazy to wire them in by quickie. Hope this helps.
I finally got around to ordering the Edcor EM0735 transformers. Now that I have them before me, I have to admit that I probably have no business with a soldering iron in my hands. I have no clue as to how to hook the new transformers into my Quickie's circuit in place of the Specos. I'd imagined something like the signal ground going to both the C.T. and Common taps on the primary and secondary; the signal going to the 8K ohm tap on the primary and the output going from the 250 ohm tap of the secondary to the headphone jack, but I don't really look forward to smoking my little Quickie. I'd be very thankful for any help I can get on the proper wiring procedure for this transformer. The pin assignments for the EM0735 are as follows:
Primary
Pin 1 8K Ohm
Pin 2 Center Tap
Pin 4 8K Ohm
Secondary
Pin 5 250 Ohm
Pin 6 32 Ohm
Pin 8 Common
Stephen
