Pages: [1]   Go Down
Author Topic: More guitar amp questions  (Read 356 times)
dbishopbliss
Administrator
Full Member
Offline Offline
View Profile
« on: August 30, 2011, 08:19:25 AM »
I have the schematic for the amp I want to build, but it does not have any voltages or currents listed.  Is there a way to reverse engineer the voltages from a schematic?
Here's the schematic.
Logged
David B Bliss
Bottlehead: Foreplay I, Foreplay III, Paramour I w/Iron Upgrade, S.E.X. w/Iron Upgrade
Speakers: FE127E Metronomes, Jim Griffin Jordan/Aurum Cantus Monitors, ART Arrays
Other: Lightspeed Attenuator, "My Ref" Rev C Amps, Lampucera DAC
elcraigo
Jr. Member
Offline Offline
View Profile
« Reply #1 on: August 30, 2011, 08:53:40 AM »
Sure - just about anything can be reversed engineered with various degrees of pain.
Can be somewhat of a chore to do by hand. I personally would redraw the schematic electronically and create a spice model, and then run some simulations.
But, on the same website you linked, there is a version of the schematic with voltages.
It is Plexi6V6.gif  (as opposed to Plexi6V6c.gif doesn't have the c in the drawing) I did not look close, but the 'c' might be a revision, so there might be some differences between the two.
Logged
Craig Lewis (elcraigo is a nickname a good friend who grew up in Mexico gave me)
dbishopbliss
Administrator
Full Member
Offline Offline
View Profile
« Reply #2 on: August 30, 2011, 10:26:37 AM »
Doh!
I didn't bother looking at that schematic because MH said he updated errors on the original.  I imagine I will be in the ballpark using those values.
Question 2 has to do with my choice of output transformers.  According to the designer, MH, you can use the transformers intended for the popular "18 Watt" Marshalls which are based on EL84's.  The primary impedence for these transformers is 8K.  MH was using a 6K6 primary transformer.  In theory, the 8K will be more linear so it would have less distortion.  Since this is a Marshall-style guitar amp, I want the distortion.  Do you think there would be a significant difference in the sound using 8K vs 6K6?
Also, I have noticed most output transformers out there are made using M6 laminations.  I have read that many of the old Plexi-style amps actually used M19 steel.  If I understand correctly, this is a lower grade steel and is not recommended for audio use because it will saturate more easily.  Again, I'm building a guitar amp and want the distortion... I would prefer the distortion at lower levels too.  I have found a 6K6/M19 transformer intended for Trainwreck-style amplfiers. Trainwrecks are known for their great tone, so I'm thinking this would be a good match.  Do you think using the 6K6/M19 transformers would make a significant difference from the 8K/M6?
Logged
David B Bliss
Doc B.
Administrator
Hero Member
Offline Offline
View Profile WWW
« Reply #3 on: August 30, 2011, 10:50:43 AM »
There are lots of different kinds of distortion. I'm not so sure that the distortion from OT core saturation is necessarily a major ingredient in the sound you might be trying to get. If you want distortion at lower levels you usually need to have multiple stages so you can reduce the master output and overdrive the intermediate stages. Unfortunately in most amps this creates triode distortion rather than the usually more desirable pentode distortion you get by overdriving a pentode output stage. A better approach might be to use a less sensitive speaker and/or an L pad brake so you can overdrive the output stage.
A good book that deals with a lot of this stuff is Gerald Weber's All About Vacuum Tube Guitar Amplifiers.
Logged
2wo
Sr. Member
Offline Offline
What? you want to look at my ugly mug?
View Profile
« Reply #4 on: August 30, 2011, 08:16:51 PM »
You might try one of the small Hammond, what is it? 125 series? Lots of taps. might find what your looking for...John
http://angela.com/hammond125seseriessingleendedoutputtransformers.aspx
Logged
John Scanlon
Pages: [1]   Go Up
Jump to:
