Pages: 1 [2] 3   Go Down
Author Topic: Wardsweb Big Speakers  (Read 7261 times)
Wardsweb
Full Member
Offline Offline
View Profile WWW
« Reply #15 on: November 28, 2009, 04:47:06 PM »
FINALLY they are back playing in my living room. I was going to leave the grills off but you will notice the left dust cap is dented. That is compliments of our 6 year old grandson and his marshmellow gun. You can't leave kids alone for two minutes. :(
My wife said she wants the full grills cut down so the big horn is showing. Sounds like a neat look. What do you guys think about a 3/4 grill?
These have not been polished yet. I need to let them cure for a few weeks before I do that.
Logged
Dr. Toobz
Sr. Member
Offline Offline
BH: So easy, even a shrink can do it.
View Profile
« Reply #16 on: November 28, 2009, 07:16:31 PM »
I think they look awesome as is, with no grills. I'm surprised that your wife actually wants the big horns showing - that's the opposite response from what I would normally expect (i.e., "cover those damn things up or get rid of them!"...)
Logged
-Angelo
Hero Member
Online Online
View Profile
« Reply #17 on: November 28, 2009, 07:31:48 PM »
I think a 3/4 grill, curved to match the horn lip, would look great. You can get (if you look around) metal perforated plate with a large percent open area, I think over 60% is available though not common. That's fairly transparent acoustically, especially below 5kHz. Perhaps a bit of black or gray soft felt between the grill and front panel would help minimize any residual cavity resonances...
Logged
Wardsweb
Full Member
Offline Offline
View Profile WWW
« Reply #18 on: November 28, 2009, 08:38:13 PM »
Way ahead of you Paul. I made full grills that follow the 22 degree arch of the speaker fronts out of perf metal, some JBL blue grill cloth and automotive trim edging. These are the ones my wife wants cut down so you see the Altec horns.
FYI: The perf is steel, 22 gauge, 1/4" hex x 0.285" on staggered centers. This makes it 77% open area. Purchased online from http://www.perf-plus.com
Logged
xcortes
Sr. Member
Offline Offline
View Profile
« Reply #19 on: November 29, 2009, 08:38:53 AM »
They are just spectacular. Can you share your crossover?
Logged
Xavier Cortes
Wardsweb
Full Member
Offline Offline
View Profile WWW
« Reply #20 on: November 29, 2009, 01:53:18 PM »
Here they are with full grills.
Logged
Mudhiker
Newbie
Offline Offline
View Profile
« Reply #21 on: December 19, 2009, 06:55:26 AM »
I can pretty much get the veneer on now, doing it just as you say.  But I am still fighting the finish.  Current method is to use sanding sealer, then spray on lacquer with HVLP sprayer, sanding between every two coats. Getting the right ratio of thinner to lacquer is so far sheer guess work. Then finally polish using an orbital car polisher and Griot's different levels of machine polish.  My finished product looks OK, but not like the dash on a Rolls Royce, which is what I aspire to. There are still small errors, both in the wood and in the lacquer, that show on close examination.   I have been practising by refinishing the bases of my Bottlehead gear (you can sand away like mad, which you cannot do on the veneer), and am now making a small pair of veneered speakers on which to experiment further.  Have also ordered a book from the library on refinishing, so eventually I should be able to do it.
What kind of lacquer are you using and what are you thinning with?  If you find yourself thinning quite a lot try moving up to a bigger nozzle on your HVLP.  Are you using a turbine or compressor driven system?  Nothing beats practice.  And a bright halogen shoplight illuminating the work from the side can show imperfections and dust on your work that are otherwise invisible to the hands and eyes.  Buy some good cabinet grade plywood to practice on and cut it into several chunks.  Sand it with a random orbit 120-180-possibly 240 but no higher. Tack it off good, apply thinned vinyl sealer, scuff sand, and then start lacquering.  If your shop temperature is reasonably close to 70 F, you should be able to sand and recoat within an hour or two.  Let the final coat harden 24 hours or more before you try polishing.  Unless you are sure of what you are doing it is a good idea to do your between-coat sandings by hand.  3M makes some foam rubber sanding pads that are fantastic for this step.  I use the Superfine.  They are about 3/16" thick and rectangular, grey in color with red lettering on the back.  Their rectangular shape will just fit on an old-fashioned quarter sheet sander, which is what I use to speed things up.  3M scotch-bright pads can also be used, the gray ones are about right.
Gloss shows everything, and like a previous poster said, preparation is key.  If there is a scratch, swirl, or dust spec in the sprayed finish, polishing will not make it go away.
Logged
Isaac Gorton
2wo
Full Member
Offline Offline
What? you want to look at my ugly mug?
View Profile
« Reply #22 on: December 19, 2009, 12:58:47 PM »
Wow, looks great,  I am with you on the ¾ grills and I see that you are looking a metal. Have a look it some of the expanded sheet metal, the stuff that is slit then stretched  to form diamond shaped spaces. Might be able to get it at home desperate…John
Logged
John Scanlon
Paully
Sr. Member
Offline Offline
View Profile
« Reply #23 on: August 16, 2010, 05:45:35 AM »
Do you have a schematic and/or picture of the crossover you used?  I think I read on another site that you used an adjustable L-pad.  Do you have any idea what frequency cut-offs you ended up at?
Those look like something that would be fun to try to build over time.  If I was going to do it I would end up doing a regular square cabinet.  I barely have the skills for that, but boy I would love to try.  I find the Altec 846A I use are wonderful but they lack something in the bass, which isn't a big deal, but much more noticeable is the compression in the highs in complex passages.  Whole bits of high frequency music are just missing when the musical passages have a lot going on.  I imagine a tweeter could go a long way to remedying this.  I would love to take a shot at something like what you built but toned down to my skill level.  How about a consulting fee?  :)
Logged
Wardsweb
Full Member
Offline Offline
View Profile WWW
« Reply #24 on: August 16, 2010, 06:13:14 AM »
Here is the final schematic.
Logged
Paully
Sr. Member
Offline Offline
View Profile
« Reply #25 on: August 16, 2010, 08:39:00 AM »
Very helpful.  I am seriously considering giving this a go, though the cabinet and quality of the actual components would have to be a little bit reduced from yours for the woofer and tweeter.  Might try a super tweeter on my current Altecs first.  But that looks like it would just be an absolute hoot to build and try out.  If I go vintage the only truly sunk costs will be the cabinets.  Everything else could be resold if it didn't work out.  We'll see if I feel like I have the hutchspa to take on such an in depth project, my fear is screwing up the basic design of the cabinet.  But thanks for posting the crossover!
Logged
Tube Newbie
Newbie
Offline Offline
General Knucklehead
View Profile
« Reply #26 on: August 16, 2010, 04:44:17 PM »
I have to agree with your wife WW.  I really like horns, they're kind of like breasts, I gotta see 'em.  Does that make me horny.....  Just askin'.  Here I am, new to the forum, and I'll probably get myself in trouble.
Sorry, if I offended anyone!!
Ron
Logged
Wardsweb
Full Member
Offline Offline
View Profile WWW
« Reply #27 on: August 16, 2010, 07:29:07 PM »
Let's just say we like things in pairs: speakers, amps, tubes...
Logged
Grainger49
Hero Member
Offline Offline
Audio Cheapskate
View Profile
« Reply #28 on: August 17, 2010, 02:46:16 AM »
Wardsweb,
The speakers really compliment the flooring.  I recognize the table (where are the cold cathodes?), the CDP and I think I see a PS Audio P-??? at the bottom.  But what are those amps next to the speakers?
Logged
Grainger Morrison,
Wardsweb
Full Member
Offline Offline
View Profile WWW
« Reply #29 on: August 17, 2010, 06:53:51 AM »
Wardsweb,
The cold cathodes are there (turntable & amp stands), just not turned on in the picture. The power conditioner is a PS Audio Quientessence. I swapped the Shanling T-100 for a C-T1500 a few months ago. The amps are Shanling SP-80 fitted with 6CA7EH. The biggest changes since that picture are the McIntosh C-36 and Juicy Music Tercel have been replaced with a SST Ambrosia preamp w/built in phono.  The rack now uses one less shelf.
Logged
Pages: 1 [2] 3   Go Up
Jump to:
