Pages: [1]   Go Down
Author Topic: more FPIII heater supply resistor values for various tubes  (Read 419 times)
John Roman
Sr. Member
Offline Offline
View Profile
« on: October 03, 2011, 12:59:41 PM »
I'm changing my extended fp 3 to use 6sn7's as output tubes, keeping the 12au7 as shunt. The existing heater resistor is composed of two parts, one is a .62 ohm/5w and a piggybacked  1.2 ohm/3w. My configuration calls for a .15 ohm/5w. Do I leave the piggybacked resistor out as well?
« Last Edit: October 04, 2011, 07:26:42 AM by Doc B. » Logged
Regards,
John
Extended Foreplay 3 / 300B Paramount's / BassZilla open baffle / Thiel CS 1.6/ Velodyne HGS-10 / Music Streamer 2 / Lenovo Y560-Win7-Pandora-Foobar 2000
Laudanum
Hero Member
Offline Offline
View Profile
« Reply #1 on: October 03, 2011, 04:45:39 PM »
John, I was going to leave this one alone since I dont have the extended and Im not one of the gurus.  But I believe that the .62 ohm resistor was paralleled with the 1.2 ohm as part of the extended upgrade (about .41 ohm total).  The Stock FPIII uses a 1.2 ohm.  The stock FPIII with 6SN7's uses a .22 ohm.   Deducing from Docs sticky post on top of this forum on resistors for different tubes in FPIII, as well as going by Pauls post to you regarding a .15 ohm resistor for extended FPIII conversion to 6SN7's ...  I think that your total resistance desired is .15 ohms.   But it would be completely understandable if you want to wait on confirmation from a more highly evolved electronic mind :-)
Logged
Desmond G.
John Roman
Sr. Member
Offline Offline
View Profile
« Reply #2 on: October 03, 2011, 05:23:44 PM »
Thanks Desmond,
I think you're right, that the .15 is correct. That's what I was thinking also but I tend to be cautious. That's the only thing left to do then I'll power it up and check some readings. I'm tempted but will probably wait.....
Perhaps you don't give yourself enough credit. Thanks for the help.
Logged
Regards,
John
Laudanum
Hero Member
Offline Offline
View Profile
« Reply #3 on: October 03, 2011, 06:15:39 PM »
I usually dont give myself enough credit for good reason :-)
I read Pauls reply in the other thread.  I was pretty confident on this one but not knowing 100% for sure, I wouldnt feel right not tempering my reply.  If I were doing it, I would have dropped the .15 ohm in and been comfortable with it.  But, then it's on me and my stuff if Im wrong, not someone elses.
Really though, if I was 100% sure about something I would just say so.  It's not often the case.
And I'm very cautious myself.  Some of my questions are just dumb, and 99% of me knows that they are dumb but that 1% of me still has to ask them to be 100% sure.
Anyway, glad you're on the home stretch.  It'll work fine.
Logged
Desmond G.
Hero Member
Offline Offline
View Profile
« Reply #4 on: October 03, 2011, 06:18:47 PM »
OK, too much confusion so it's time to post these numbers again.
First, of course, you all know that we don't "support" modifications to the products. Nobody does, because nobody can. We DO encourage those who wish to try things, and help out where we can - it's a great hobby!
Under the "helping out" label, I have posted the appropriate resistor value to get 6.3 volts DC from a PT-3 when the input line voltage is 120vRMS. Here are the numbers, current in column 1, resistor in column 2, notes in column 3:
0.3A  1.37ohm
0.6A  0.61ohm (stock FP has 0.62)
0.9A  0.35ohm (stock Extended has 0.62 paralleled with 1.2 equals 0.41ohm)
1.2A  0.22 ohm (stock FP with 6SN7s would use this)
1.5A  0.15ohm (this is what John has)
1.8A  0.10ohm (SEX amp, or eXtended Foreplay with three 6SN7s)
2.1A  0.06ohms (a SEX amp with 6EM7s - though I would just use the 0.1 ohm, it's not that different.)
The formula, which is just a curve fit, is approximately as follows:
V = 7.10 – 1.75*I*(R+0.16)
The value 7.1 would change in approximate proportion to the difference in line voltage from the nominal 120v.
All these are approximate numbers, which ignore the difference in current drawn from the high voltage supply. It is always a good idea to measure the resulting heater voltage once it is built, and adjust it if it deviates more than you are comfortable with from the spec, or from your target if you have chosen a different target from the specification (as I did with the Seduction design). For Foreplay, an ideal range would be 6.0 to 6.3 volts in my opinion, and an acceptable range would be the usual +/-10%, i.e. 5.7 to 6.9 volts.
« Last Edit: October 04, 2011, 07:26:15 AM by Doc B. » Logged
Pages: [1]   Go Up
Jump to:
