Pages: [1]   Go Down
Author Topic: Driver tube bias?  (Read 462 times)
jlschweiger
Newbie
Offline Offline
View Profile
« on: November 05, 2011, 07:59:22 PM »
Still wet behind the ears here, should I be checking the driver tube bias every so often as a "check up" or does this only need to be done if the driver tubes are replaced?  Really enjoying the Paramounts...
Thanks for any replies!
Logged
John Schweiger
Adcom GCD-575 -> Paramounts -> Heresy III
iPod classic (lossless) -> Apple dock line-out -> Smack -> HD800
Doc B.
Administrator
Hero Member
Offline Offline
View Profile WWW
« Reply #1 on: November 05, 2011, 08:05:08 PM »
No checkup necessary. The only indicator of needing a new tube is if the one in the amp sounds like it is worn out, i.e. the overall sound is getting flat. Even if a tube is getting long in the tooth sonically it won't hurt anything.
Logged
jlschweiger
Newbie
Offline Offline
View Profile
« Reply #2 on: November 30, 2011, 06:43:03 PM »
I'm considering trying some tube rolling with some WE396A's as the driver tubes.
Would I need to check/adjust the bias if I substitute these for the original driver tubes?
Logged
John Schweiger
Hero Member
Offline Offline
View Profile
« Reply #3 on: November 30, 2011, 06:54:59 PM »
Yes, the bias should be adjusted when a new tube is substituted. I would check it again after about 100 hours - it probably won't have drifted, but if it does, adjust and check in another 100 hours. After it's stable, most tubes will go for years with very little drift. But each tube is different - even the same brand, date, and type - so re-check when you change tubes.
I think you want to be within 5% if you are set up for 2A3s; the 300B with cap coupling can be off by 10% with little audible effect.
Logged
jlschweiger
Newbie
Offline Offline
View Profile
« Reply #4 on: December 12, 2011, 09:00:00 AM »
Mr. Joppa,
Thank you for your reply, Sir!
Logged
John Schweiger
Pages: [1]   Go Up
Jump to:
