Pages: 1 [2] 3   Go Down
Author Topic: Vibration and Isolation  (Read 1468 times)
Thoburn
Full Member
Offline Offline
View Profile
« Reply #15 on: December 26, 2011, 07:51:18 PM »
Hi Granger,
I like the glass bead idea to. IIRC you live in Colorado. I'm in Washington state. If we were closer I would happily split the purchase price with you.
I'm in Knoxville, TN.  I expect the cheapest shipping would cost the price of a whole bag of beads.  But thanks for the thought.
Won't the sand settle after a little while?  I suspect the glass beads do too.
I forgot to mention that as I added layers of sand I tapped around the frame with a rubber mallet to get the settling started. It has been a couple days now and I don't see any uneven settling. The bubble level show the same on the platter as it did in the beginning.
Logged
A problem with communication is the assumption it has been achieved - source unknown
bainjs
Full Member
Offline Offline
View Profile
« Reply #16 on: December 27, 2011, 07:56:35 AM »
What feet did you end up using?
Logged
Joel Bain
Thoburn
Full Member
Offline Offline
View Profile
« Reply #17 on: December 27, 2011, 09:38:27 AM »
I picked up 2 canisters of racket balls at Target for about $8. I cut them along the seem with a one sided razor. It was surprising how tough they are. There are 12 half-balls under the sand table. You can see their turquoise bottoms between the shelf and the sand box. The bottom of the sand box is 1/2 inch up from the bottom of the sides. I think I mentioned that I used 3/8 poly instead of the 1/4 mentioned in the design. I went with the 3/8 because my Scout II table is about 40 pounds and I wanted to spread the weight around as much as I could.
Logged
bainjs
Full Member
Offline Offline
View Profile
« Reply #18 on: December 27, 2011, 12:25:26 PM »
Thanks, that's a pretty good idea.
Some people also use small super balls sitting in rubber washers or o rings to keep them from rolling and just sit the base on them.
Sounds like some experimenting coming up!
Logged
Joel Bain
Thoburn
Full Member
Offline Offline
View Profile
« Reply #19 on: January 17, 2012, 09:36:00 PM »
It has been about a month now and I have been checking the level of the turn table. No change so far. I think the tapping with must have helped a lot. Very pleased with the results.
Logged
bainjs
Full Member
Offline Offline
View Profile
« Reply #20 on: January 18, 2012, 09:46:17 AM »
I'm thinking of building some for my speakers.  Would you still use the Raquet Balls as feet? I don't have carpet.
Logged
Joel Bain
Grainger49
Hero Member
Offline Offline
Audio Cheapskate
View Profile
« Reply #21 on: January 18, 2012, 10:02:09 AM »
Bainjs and I are considering build a couple of these for our turntables.
Thanks for the update.
Logged
Grainger Morrison,
Thoburn
Full Member
Offline Offline
View Profile
« Reply #22 on: January 18, 2012, 08:46:23 PM »
Hi,
I think for the price it is worth a try. I kind of like the superball in washer idea as well. I wonder if 'floating' speakers is the right thing to do. It seems to me that most speakers use spikes to 'anchor' them solidly to the floor. I think that keeping the driver frame from moving lets the cone transfer as much sound energy as possible. Just a guess on my part.
Logged
Grainger49
Hero Member
Offline Offline
Audio Cheapskate
View Profile
« Reply #23 on: February 07, 2012, 06:57:53 AM »
Joel sent the box, beautiful work!  I bought a bag of glass beads from Harbor Freight.  I have ordered a piece of glass and I have veneer to finish the box front and sides.  Then it all gets loaded into my shelf below my VPI table.
Thanks to Joel (bainjs), and all the posters.  Here is hoping!
Edit: I thought this link was in here but I didn't find it this morning.  This is another vintage Bottlehead pRC:
http://www.cognitivevent.com/sandbox.html
« Last Edit: February 09, 2012, 06:06:19 AM by Grainger49 » Logged
Grainger Morrison,
Thoburn
Full Member
Offline Offline
View Profile
« Reply #24 on: February 16, 2012, 10:36:26 AM »
I used 3/8 inch poly carbonate instead of glass as that is what the design called for. I have no idea if it makes much difference. Still no sign of uneven settling. I'd like to hear about other folks results. How is it sounding?
Logged
Grainger49
Hero Member
Offline Offline
Audio Cheapskate
View Profile
« Reply #25 on: February 16, 2012, 01:36:15 PM »
I think you were looking at the pRC site and I was looking at the Wardsweb site.  They call for slightly different setups.
Logged
Grainger Morrison,
bainjs
Full Member
Offline Offline
View Profile
« Reply #26 on: February 16, 2012, 04:53:58 PM »
I went with the real cheap and made mine from 1/2" MDF.  No settling here either.
Logged
Joel Bain
magnafuzz
Newbie
Offline Offline
View Profile
« Reply #27 on: February 16, 2012, 05:11:07 PM »
After reading this thread I built up a sandbox for my Rega Planar 3. I built it to match the dimensions of my TT to hide things away and tried to make it look like it was part of the TT. Now the base will match my Crack and soon to ship Seduction. I used 3/8" poly as well. For feet i used soft foam hockey pucks, works well. I also use them under my weighted speaker stands (my springy floor creaks and shakes when my speakers are directly on the floor).
Logged
Andrew T
Seduction
Crack with speedball
Grainger49
Hero Member
Offline Offline
Audio Cheapskate
View Profile
« Reply #28 on: February 17, 2012, 07:07:29 AM »
Andrew,
That didn't look like a sandbox till I read the text.  I clicked on the thumbnail first.  It looks like a turntable with a "normal" base.  Nice job!
Logged
Grainger Morrison,
4krow
Jr. Member
Offline Offline
CONSIDER THE SOURCE
View Profile
« Reply #29 on: February 17, 2012, 10:45:03 AM »
For those of you interested in using washers for super balls to sit in, I have been using Sorbothane rings for some of my projects. I found them on ebay for a really cheap price. They are 30D, which means they are soft. Each one is rated for 5#, so, a series of them would be very effective. I think I paid $9 postage paid, and shipped really fast.
Logged
Greg Peyton
 System makeup: Audio Nirvana integrated amp(6V6 tube);Cayin cd22 cd player; Forte' 3 bass amp; Decware ZOB speakers; BESL subs w/Velodune sms-1; upgraded Carver C9 holographic processor.
Pages: 1 [2] 3   Go Up
Jump to:
