Pages: [1]   Go Down
Author Topic: Top plate prep for lacquer  (Read 667 times)
Oldlistener50
Newbie
Offline Offline
View Profile
« on: January 24, 2012, 02:47:15 PM »
Got my Seduction kit... whoopee!  I want to do the top plate in deep-gloss black lacquer.  Will cleaning with an alcohol wipe be sufficient and not adversely react with the lacquer?
Logged
Doc B.
Administrator
Hero Member
Online Online
View Profile WWW
« Reply #1 on: January 24, 2012, 03:03:33 PM »
Alcohol will be fine. However, lacquer is a thin finish and the graining might show through. If you want a deep gloss you might want to sand the panel with progressively finer wet or dry paper before you shoot it.
Logged
sl-15
Newbie
Offline Offline
View Profile
« Reply #2 on: January 25, 2012, 10:16:24 PM »
i am no expert on this but you might want to consider using a primer first. this might depend on the lacquer you want to use. but generally a primer makes the paint stick better, but it also fills voids. that way you do not have to go crazy on the sanding. i am in the middle of restoring an old Rek-O-Kut turntable and was sanding of the old paint on the top plate. there were two layers of primer underneath and now that everything is stripped you really see more imperfections in the top plate then before. try out your paint and/or primer on the underside first in one small spot were you do not have to write numbers. that way you can tell your results before really going for it. acetone would be a good prep for the top plate. it will remove grease and oily residue the best but it can leave some residue of its own so it would be good to follow up with denatured or isopropyl alcohol. if you do not want to go for acetone which is kinda nasty and can be pricy use dish soap and water and then follow up with isopropyl alcohol. hope this helps.
Logged
stefan hampel
ortofon sl-15 with step-up, technics sl-1200mkII, seduction c4s, foreplayIII, marantz pm 7000 and hafler pro1200, b&w 602 S3 bookshelf
Oldlistener50
Newbie
Offline Offline
View Profile
« Reply #3 on: January 26, 2012, 09:03:19 AM »
Yes, great ideas thanks guys.  I also thought about the primer route, I need to find some primer that can be used underneath lacquer.
Thanks.
Logged
lextek
Jr. Member
Offline Offline
View Profile
« Reply #4 on: January 26, 2012, 05:08:11 PM »
Great idea of high-gloss black should look awesome with glowing tubes.
Logged
Bob Lasky
Noskipallwd
Full Member
Offline Offline
View Profile
« Reply #5 on: January 26, 2012, 09:57:29 PM »
Hello, I've used BIN Bullseye shellac based primer with good results. It works well on metal or wood. I use it to prime MDF, which is always a PITA but this makes it a little more bearable.
Shawn P.
Logged
Shawn Prigmore
Doc B.
Administrator
Hero Member
Online Online
View Profile WWW
« Reply #6 on: January 27, 2012, 08:10:32 AM »
+1, shellac is an excellent primer for lacquer, at least that's my experience using it on wood.
Logged
Oldlistener50
Newbie
Offline Offline
View Profile
« Reply #7 on: January 29, 2012, 08:33:46 AM »
Well, it's primed and painted.  Used the BIN primer and Rustoleum black lacquer.  Came out really nice!  Pic isn't that good due to reflections but it has a nice piano black gloss to it.
Gonna let it bake on for a few days before I touch it (sitting elevated in a box on top of one of my radiators).
Logged
4krow
Jr. Member
Offline Offline
CONSIDER THE SOURCE
View Profile
« Reply #8 on: January 29, 2012, 11:51:44 AM »
Thanks for showing the results, I have found that painting/finishing is the biggest challenge of my projects. Maybe I missed it, but how far away did you hold the spray can, and how many coats?
Logged
Greg Peyton
 System makeup: Audio Nirvana integrated amp(6V6 tube);Cayin cd22 cd player; Forte' 3 bass amp; Decware ZOB speakers; BESL subs w/Velodune sms-1; upgraded Carver C9 holographic processor.
Grainger49
Hero Member
Offline Offline
Audio Cheapskate
View Profile
« Reply #9 on: January 29, 2012, 12:10:20 PM »
Give the edges a light touch. Otherwise they will be seen and stick out like a sore thumb.
The top coat looks good!  I think all the holes in the top plate are going to be filled.  I don't think they will need touching up.  Or you could just go over them with a black Sharpie.  The outer edges might take that pretty well if you don't feel like jeopardizing the top plate finish.
« Last Edit: January 29, 2012, 12:37:34 PM by Grainger49 » Logged
Grainger Morrison,
Oldlistener50
Newbie
Offline Offline
View Profile
« Reply #10 on: January 29, 2012, 12:16:06 PM »
I will drop the plate into the base and check the edges, thanks Grainger.  Didn't notice that when I test-fitted it into the base (which has been glued and is curing overnight) but will double-check.
I held the can about 6" away.  A thin coat, sanding with 320-grit, then a couple heavy coats until it really shined.
What's interesting, it's been about 6 hours since I painted it, and the gloss seems to be getting deeper as time goes by.
« Last Edit: January 29, 2012, 06:07:03 PM by Oldlistener50 » Logged
Doc B.
Administrator
Hero Member
Online Online
View Profile WWW
« Reply #11 on: January 30, 2012, 12:03:34 PM »
There was a time when the rabbet in the base was for thinner plates and the thicker plates we went to would sometimes stand a bit proud. I think that is not so much an issue with the current production as the rabbet is now deeper.
Logged
lextek
Jr. Member
Offline Offline
View Profile
« Reply #12 on: February 03, 2012, 06:39:07 PM »
You can still see the edge at certain angles.  I had to shoot the edges of my Crack.  That just sounds wrong.
Logged
Bob Lasky
4krow
Jr. Member
Offline Offline
CONSIDER THE SOURCE
View Profile
« Reply #13 on: February 11, 2012, 10:14:11 AM »
If you are brave maybe you could use a 1/8" square brass rod, cut the ends at 45 degrees, and use them as edging sitting atop the plate. It would have to be done almost perfectly, but I bet it would look great. I enjoy using brass in cases like. It is easy to work with and looks pretty classy. In my last project, I did no more than to replace cheap black screws with small brass bolts. Worth the effort.
Logged
Greg Peyton
Pages: [1]   Go Up
Jump to:
