Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News
: Now taking orders for the Tode, Bottlehead's new guitar amp kit!
Calendar
General Category
Technical topics
C4S/shunt regulator test
Pages: [
Author
Topic: C4S/shunt regulator test (Read 1263 times)
ducati guy
Newbie
Offline
November 30, 2009, 11:46:08 AM »
Is there an easy way to test a C4S/shunt regulator combo? I was thinking of hooking it up to the power supply with a load resistor that would approximate the current draw (~52 mA). Reasonable?
Logged
Hero Member
Offline
Re: C4S/shunt regulator test
Reply #1 on:
November 30, 2009, 11:54:08 AM »
You mean, hook it up and see if it smokes? That ought to work...
If the shunt regulator can handle all the C4S current then you don't need to simulate the load for a quick check, but the internal voltages and currents won't be the same as in normal operation so a full simulation as you described is a better check.
Logged
ducati guy
Newbie
Offline
Reply #2 on:
November 30, 2009, 11:56:11 AM »
Thanks. I'll hook it up and see what happens!
Logged
Grainger49
Hero Member
Offline
Audio Cheapskate
Reply #3 on:
December 07, 2009, 12:12:37 PM »
IIRC, VoltSecond had a test for C4S boards using a 9V battery. It would test the LED orientation, transistor wiring but I don't know if it gets to the rated current.
Is that possible?
Logged
Grainger Morrison,
ducati guy
Newbie
Offline
Reply #4 on:
December 09, 2009, 08:18:03 AM »
Tried the full power test and everything appears to be working fine. Voltages and current are as expected. Was a bit concerned since I had never had a printed circuit board made before and despite checking many, many times, worried about a mistake in the connections.
Logged
Grainger49
Hero Member
Offline
Audio Cheapskate
Reply #5 on:
December 09, 2009, 08:41:34 AM »
You
always
worry about
the smoke test
. On my first kit, 1965, cheap, Japanese, wrong instructions, wrong schematic (I had to be told I couldn't know), paper/foil/wax
cheap caps
we (my brother and I) exploded the wax caps on several attempts. Luckily the kit had extra parts.
Logged
Grainger Morrison,
Pages: [
Jump to:
Please select a destination:
General Category
=> Forum Rules
=> General Discussion
=> Bottlehead Special Deals
=> VALVE archive
=> Technical topics
=> Tech Tools
=> All things MagneQuest
=> Grainger's Corner
Bottlehead Kits
=> Gallery
=> Quickie
=> Crack
=> Smack
=> Foreplay III
=> Seduction
===> Seduction Tape Head Preamp
=> Eros Phono
=> Eros Tape
=> S.E.X. Kit
=> Stereomour
=> Paramount
=> Bottlehead Power Cord Kit
=> Technics Tape Path Kit
=> Tode
=> Legacy Products
Bottlehead Finished Products
=> Tube Phono
=> Tube Repro
Other Gear
=> Speakers
=> Headphones
=> Phono
=> Digital
=> Reel to Reel Tape
Loading...
