Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News
: Now taking orders for the Tode, Bottlehead's new guitar amp kit!
Calendar
Bottlehead Kits
Foreplay III
foreplay volume resistors..
Pages: [
Author
Topic: foreplay volume resistors.. (Read 1030 times)
rucyrius
Newbie
Offline
December 09, 2009, 06:51:20 AM »
so i've put in some resistors on two inputs of the foreplay. on input one i put -6 resistors, input two -18 resistors ... input one worked fine as did input two.. now all of a sudden input one right side doesn't work...i checked connections and they are good .. could it have burned out or something.. also does it matter which way the colors of the resistor face? .... i noticed one this resistor is facing different than the rest..
thanks
john
Logged
Grainger49
Hero Member
Offline
Audio Cheapskate
Re: foreplay volume resistors..
Reply #1 on:
December 09, 2009, 07:15:15 AM »
Resistors do not have any direction. The one that is "reversed" will work fine. Capacitors, transistors and diodes have a direction that are very important.
Sounds like a faulty solder joint. There should have been only two solder joints associated with input one right side. Regardless of how they checked, first measure the resistance from one lead of the "bad" resistor to the other lead. Remember it is probably +/- 10% of the stated value. Then wiggle both ends and see if there is any play. Finally reheat the solder joints and see if it doesn't clear up.
Logged
Grainger Morrison,
Pages: [
Jump to:
Please select a destination:
General Category
=> Forum Rules
=> General Discussion
=> Bottlehead Special Deals
=> VALVE archive
=> Technical topics
=> Tech Tools
=> All things MagneQuest
=> Grainger's Corner
Bottlehead Kits
=> Gallery
=> Quickie
=> Crack
=> Smack
=> Foreplay III
=> Seduction
===> Seduction Tape Head Preamp
=> Eros Phono
=> Eros Tape
=> S.E.X. Kit
=> Stereomour
=> Paramount
=> Bottlehead Power Cord Kit
=> Technics Tape Path Kit
=> Tode
=> Legacy Products
Bottlehead Finished Products
=> Tube Phono
=> Tube Repro
Other Gear
=> Speakers
=> Headphones
=> Phono
=> Digital
=> Reel to Reel Tape
Loading...
