Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News
: Now taking orders for the Tode, Bottlehead's new guitar amp kit!
Calendar
Bottlehead Kits
Foreplay III
Extended Foreplay Coupling Caps
Pages: [
Author
Topic: Extended Foreplay Coupling Caps (Read 1294 times)
J Leng
Newbie
Offline
December 14, 2009, 01:07:11 PM »
Am I correct in thinking that if my power amp has an input impedence of 100k then I only need the coupling capacitor value to be 0.47uF and any large capacitor will not make any difference to the sound quality?
Logged
Hero Member
Offline
Re: Extended Foreplay Coupling Caps
Reply #1 on:
December 14, 2009, 04:19:28 PM »
For frequency response you are correct.
However, there is a hum-reduction argument that says to keep the source impedance of the capacitor no greater than the preamp's output impedance at 60Hz. That works out to be 3.8uF for a Foreplay III.
If it were me, I'd go ahead and try it. If there is any hum or interference problem, just replace the original cap leaving the new one in place as a bypass. (I'm assuming you ask because you have a higher-quality 0.47uF cap in mind as an upgrade ... )
Logged
J Leng
Newbie
Offline
Reply #2 on:
December 15, 2009, 02:40:31 AM »
Thanks for that, would the hum be present on all sources, as there is hum present on my phono stage?
Logged
Hero Member
Offline
Reply #3 on:
December 15, 2009, 08:48:59 AM »
It's an output thing, so would be present identically on all sources.
For what it's worth, I had the same thing - hum on phono only - which disappeared when I changed phono preamps.
Logged
J Leng
Newbie
Offline
Reply #4 on:
December 15, 2009, 09:55:06 AM »
I thought so, I've just changed op amps in my phono stage to a discreate GD Audio op amp and I think that's where the problem is.
J
Logged
Pages: [
Jump to:
Please select a destination:
General Category
=> Forum Rules
=> General Discussion
=> Bottlehead Special Deals
=> VALVE archive
=> Technical topics
=> Tech Tools
=> All things MagneQuest
=> Grainger's Corner
Bottlehead Kits
=> Gallery
=> Quickie
=> Crack
=> Smack
=> Foreplay III
=> Seduction
===> Seduction Tape Head Preamp
=> Eros Phono
=> Eros Tape
=> S.E.X. Kit
=> Stereomour
=> Paramount
=> Bottlehead Power Cord Kit
=> Technics Tape Path Kit
=> Tode
=> Legacy Products
Bottlehead Finished Products
=> Tube Phono
=> Tube Repro
Other Gear
=> Speakers
=> Headphones
=> Phono
=> Digital
=> Reel to Reel Tape
Loading...
