I recently decided to rebuild my Paramour I with upgraded everything. This thread will be to chronical the rebuild as parts come in and to bounce any further ideas about the rebuild off the respective big brains that lurk the board.
First up the top plates have come in as well as a few of the caps for the power supply. For the power end planning on a PT-2 to a full wave Schottky, into a CLCRC filter. 40uf, 50h, 40uf, 1.1k, 47uf. The 40uf motor runs and 47uf Solen can be seen in the pic bellow. And the rebuild will be for 45s not 2a3s hence the large resistor value.
In need of much more room for capacitors and a desire to bring the signal pathway further into the 3rd dimension to maintain short path but maximize keeping power away from signal and improved ground paths I went with a couple of huge aluminum C channels. 13x8x3.75. Planning on tapping all bolts directly into the aluminum to reduce vibration and so that no bolts are externally visible.
I still have not figured out how I am going to cut through the aluminum for the top mounted iron. I know have drill bits that will go through aluminum that thick but I am fairly certain that I don't have anything that will cut it.
Any suggestions?
I am off to sanding and polishing.
Be well
