Pages: [1]   Go Down
Author Topic: Cathode capacitor, do I need one?  (Read 661 times)
fdandrews
Newbie
Offline Offline
View Profile
« on: February 09, 2010, 08:14:38 AM »
Hi! I'm in the middle of building a parallel feed amp with a 6W6 output tube and cathode bias. I plan to use it only above 100hz in a biamped system. Does the cathode resistor still need a capacitor across it? Can I leave it out to reduce the low frequency signal going to the main speakers?
Logged
Hero Member
Offline Offline
View Profile
« Reply #1 on: February 09, 2010, 10:12:26 AM »
That would probably work well. Return the output transformer to the cathode, not to ground, so that the bias resistor is not part of the midband signal current loop.
Logged
Pages: [1]   Go Up
Jump to:
