Pages: 1 [2]   Go Down
Author Topic: How quiet is quiet?  (Read 2706 times)
tbbenton
Newbie
Offline Offline
View Profile
« Reply #15 on: February 17, 2010, 09:57:23 PM »
Quote
I do see your reasoning, but the current available to charge that cap will be 23.5ma, 90ma won't pass through the top CCS.  Also the cathode voltage and anode voltage are both zero until the shunt regulator starts conduction, so the reference terminal is free to vary a bit.  This has worked on the shunt regulators in many Extended Foreplay III's.  If we had a fet in there instead of a tube, then I might be pretty worried.
Good point on the current source.  How much current does the tube sink?  Assuming worst case that 23 mA runs through the 2.49k R3, then there's about 60v on the 431, which is way above maximum rating of 37v.  This capacitor bypass is bad news.  I tried it and fried my Eros.
Logged
Tom Benton
Caucasian Blackplate
Sr. Member
Offline Offline
View Profile
« Reply #16 on: February 17, 2010, 10:25:12 PM »
Hmm, that is not good news!  PM me and I can ship you another board.  I will have to take some measurements in my FP-III and Eros related circuit to see why this might happen...  What was the exact failure in your Eros?
Logged
Hero Member
Offline Offline
View Profile
« Reply #17 on: February 17, 2010, 10:28:30 PM »
Just a note - the Eros does not have any cathode followers, all the stages are isolated from power supply noise by current sources. Making the shunt regulator even quieter won't affect the noise, which comes from other sources - mostly the EF86's thermal noise floor.
Logged
tbbenton
Newbie
Offline Offline
View Profile
« Reply #18 on: February 17, 2010, 11:09:03 PM »
Snapping sound and a flash of light, not in that order, of course.  All LEDs dead.  The resistors all still measure good, but replacing the 431s alone (from above - didn't remove the pc) didn't bring it back to life.  I will need to perform further tests.
Logged
Tom Benton
tbbenton
Newbie
Offline Offline
View Profile
« Reply #19 on: February 25, 2010, 03:52:12 PM »
Follow up:   My TL431s were indeed toasted and the LEDs on the shunt reg board were all shorted by the event.  Thanks to Paul, I received and installed a new shunt reg board and my Eros is back in fine form.  I am happy to have things working again and I have no plans to monkey any further with the power supply.
Logged
Tom Benton
Pages: 1 [2]   Go Up
Jump to:
