Pages: 1 [2]   Go Down
Author Topic: Finished my First Quickie  (Read 3155 times)
Wardsweb
Full Member
Offline Offline
View Profile WWW
« Reply #15 on: June 16, 2010, 01:03:35 PM »
I'm pretty familar with potentiometers, however, this control only has 4 lugs total, however, it's a stereo unit.  It doesn't make a lot of sense.
Is it wired like this
« Last Edit: June 16, 2010, 06:35:27 PM by Wardsweb » Logged
Grainger49
Hero Member
Offline Offline
Audio Cheapskate
View Profile
« Reply #16 on: June 16, 2010, 01:09:36 PM »
That means that there is a connection that isn't a lug.  I could see ground being common, but that only drops the count to five.  Hmmmm....
I looked at the link again.  Is there an obvious beginning or end to the ladder?  The last of the embedded pictures shows a connection, no ground and the connection looks to be mono, yet the item description says stereo.
« Last Edit: June 16, 2010, 01:13:31 PM by Grainger49 » Logged
Grainger Morrison,
bainjs
Full Member
Offline Offline
View Profile
« Reply #17 on: June 16, 2010, 03:37:25 PM »
Wardsweb: yes, it looks like the same one.  Any ideas?
Logged
Joel Bain
bainjs
Full Member
Offline Offline
View Profile
« Reply #18 on: June 16, 2010, 03:42:38 PM »
Here's the wiring diagram from the vendor.  It's not saying much to me....
http://www.virtualvillage.com/24-step-ladder-type-stereo-volume-attenuator-100k-001493-040.html
Logged
Joel Bain
bainjs
Full Member
Offline Offline
View Profile
« Reply #19 on: June 16, 2010, 04:07:51 PM »
The answer -
Logged
Joel Bain
IceOgre
Newbie
Offline Offline
View Profile
« Reply #20 on: June 17, 2010, 02:41:21 PM »
It really is a very simple procedure.  I used my volt ohm meter to figure out the starting point as mentioned by Graniger.  To start to the volume knob all of the way down.  Then with your volt ohm meter start turning the knob and measure the resistance.  The input gets connected to the lower side of the voltage range.  Where I got stuck was on the ground.  I ended up fixing the ground to the last resistor in the chain.  I guarantee I am not explaining myself well.  I am packing for vacation now.  If I have time this evening I will try to snap a few more pictures. Again the ground is the thing that through me for a loop.  Also, I took measurements of the existing pot while it was still intalled to educate myself.
I am new to this DIY stuff and it is fun.
Logged
bainjs
Full Member
Offline Offline
View Profile
« Reply #21 on: June 18, 2010, 04:11:37 PM »
Thanks IceOgre!
Logged
Joel Bain
balancedtriode
Newbie
Offline Offline
View Profile
« Reply #22 on: June 20, 2010, 05:57:20 PM »
the tube guards are amazing i might have to steal that idea if u dont mind ;-)
Logged
Revox B795 TT
Bottlehead Seduction
Bottlehead Stereomour
Klipsch Cornwalls' with Vertical Horns
pro_crip
Full Member
Offline Offline
View Profile
« Reply #23 on: July 01, 2010, 03:02:35 PM »
I was leafing through the Technitool catalog and noticed they sell copper tape to use as emi shielding. Would the combination of tape and copper fitting create a faraday cage, especially if you grounded the copper? Btw, love the idea so I'm going to borrow it for my amps, plus I love the color of copper.
Rich
Logged
Richard J Feldman
Professional Gimp,connoisseur of Bourbon and Vinyl, metalhead
Crack, Extended FPIII, Eros, Paramount 300B's (in the midst of construction)
Tune down, smoke up
Pages: 1 [2]   Go Up
Jump to:
