Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News
: Now taking orders for the Tode, Bottlehead's new guitar amp kit!
Calendar
Bottlehead Kits
Foreplay III
Foreplay III Second Pair of Outputs for Subwoofer
Pages: [
Author
Topic: Foreplay III Second Pair of Outputs for Subwoofer (Read 1126 times)
AudioDave
Newbie
Offline
April 12, 2010, 08:47:37 AM »
Hope this isn't to silly of a question. I would like to try using a non-powered subwoofer in my system by connecting a mono amp to the second pair of outputs on my Foreplay III. Would I simply connect the left and right outputs together using a splitter and then on to the mono amp, passive crossover, and subwoofer or is there a better way?
Dave
Logged
Hero Member
Offline
Re: Foreplay III Second Pair of Outputs for Subwoofer
Reply #1 on:
April 12, 2010, 11:13:12 AM »
Connecting them together will reduce separation on all the outputs. The simple way is to replace the 1K resistors (back by the RCAs) with at least 10K, up to 50K resistors. More resistance gives less loss of separation. The high resistance may reduce the signal, depending on the amplifier's input impedance, and it will certainly reduce the high treble due to the capacitance of the interconnect - but that's not something you need to worry about in a bass amp! The high impedance will make the cable more susceptible to picking up hum from electric fields, so choose an interconnect with a good high-coverage shield.
Instead of the speaker-level filter, you could use an active crossover, or probably even a passive line level one, upstream of the mono amp. That would reduce wasted power in the mono amp. Id you do use the passive speaker-level filter, and if the mono amp has negative feedback (i.e. solid state or push-pull pentodes) make sure there is a load at high frequencies to prevent amplifier instability.
Logged
AudioDave
Newbie
Offline
Reply #2 on:
April 12, 2010, 03:22:55 PM »
Thanks Paul, I appreciate that explanation. It was a little more involved than I thought. That's why I like to ask first!
Thanks again.
Dave
Logged
AudioDave
Newbie
Offline
Reply #3 on:
April 12, 2010, 05:05:31 PM »
After thinking about Paul's suggestions, I am leaning toward an active crossover for my subwoofer. Do any of you have a good suggestion for either a DIY or assembled active crossover for a subwoofer powered by a mono amp?
Dave
Logged
2wo
Sr. Member
Offline
What? you want to look at my ugly mug?
Reply #4 on:
April 12, 2010, 06:43:45 PM »
How about a plate amp? It has the crossover, amp, and L&R inputs all in one package…John
Logged
John Scanlon
Pages: [
Jump to:
Please select a destination:
General Category
=> Forum Rules
=> General Discussion
=> Bottlehead Special Deals
=> VALVE archive
=> Technical topics
=> Tech Tools
=> All things MagneQuest
=> Grainger's Corner
Bottlehead Kits
=> Gallery
=> Quickie
=> Crack
=> Smack
=> Foreplay III
=> Seduction
===> Seduction Tape Head Preamp
=> Eros Phono
=> Eros Tape
=> S.E.X. Kit
=> Stereomour
=> Paramount
=> Bottlehead Power Cord Kit
=> Technics Tape Path Kit
=> Tode
=> Legacy Products
Bottlehead Finished Products
=> Tube Phono
=> Tube Repro
Other Gear
=> Speakers
=> Headphones
=> Phono
=> Digital
=> Reel to Reel Tape
Loading...
