Pages: [1]   Go Down
Author Topic: Changing input load  (Read 747 times)
008452
Newbie
Offline Offline
View Profile
« on: May 05, 2010, 09:28:19 AM »
I have a C4 Seduction that I am using with a Benz Micro Ace HO. The manufacturer recommends a 1000 ohm load. Which resister do I change to get there? Assume ones attached to input jacks but want to make sure.
Logged
Caucasian Blackplate
Hero Member
Offline Offline
View Profile
« Reply #1 on: May 05, 2010, 09:47:47 AM »
You are correct, the input loading resistors attach to the input jacks and solder to the ground plane. Usually cartridges have a range of input loads they like, so you might consider buying a pair of small 50k or 100k trimmers so you can try different values.
How are things sounding with the 47k resistors?
Logged
Grainger49
Hero Member
Offline Offline
Audio Cheapskate
View Profile
« Reply #2 on: May 05, 2010, 12:18:39 PM »
I found this:
http://www.musicdirect.com/product/81700
It indicates greater than 1000 ohms.  So that gives a wide range.  Have reviews suggested a 1k ohm resistor?
Logged
Grainger Morrison,
008452
Newbie
Offline Offline
View Profile
« Reply #3 on: May 05, 2010, 04:41:02 PM »
It sounds a rough right now, but its still breaking in. Highs are a little forward. I've seen blog reviews suggesting 1000-1500. I think I'll try the trimmer idea after it breaks in. Thanks
Logged
Pages: [1]   Go Up
Jump to:
