xcortes
« on: October 19, 2009, 02:30:17 PM » |
nt
Logged
Xavier Cortes
« Reply #1 on: October 19, 2009, 07:17:03 PM » |
I doubt it.
We did a prototype, but it turned out to be pretty difficult. There are heat and reliability issues, specifically with the current source that supplies the shunt regulator. It has to dissipate nearly twice as much power as can be easily handled by a TO-220 device. Whether we go to a larger TO-3 or use two or more TO-220 or TO-126 devices, or use a tube, it will take some engineering design and experimenting time to come up with a stable, reliable design that can be built as a kit.
What makes sense to me right now is fully shunt regulated 45 amps. Once the Stereomour is out and I have a bit of time, I plan to pursue that as the first step. So far, Doc B is not very excited about such a product, but as a designer I am so I'll probably continue to work on it. I want a pair for my own system, for one thing!
Remember, shunt regulation is very inefficient The regulator will usually dissipate at least as much power as the output tube, without contributing any audio power itself. And SETs are already quite inefficient.
Logged
jrebman
« Reply #2 on: October 20, 2009, 07:43:22 AM » |
Paul,
I could get excited about an SR 45 amp too, so if you come up with a good solution, I'd be glad to give it a try.
-- Jim
Logged
Jim Rebman
Alix linux box --> HRT MusicStreamer II+ --> Crack --> Sennheiser HD-600s.
tsingle999
« Reply #3 on: October 26, 2009, 10:05:34 AM » |
I am excited about the stereomour as a SR45 product! I am currently addicted to the SR45 Paramour II. Taran
Logged
fvale
« Reply #4 on: October 26, 2009, 03:11:34 PM » |
I'm also addicted to the SR45 Paramour and I'd really like one day to see a fully SR2A3 amp from BH!
Logged
2wo
« Reply #5 on: October 29, 2009, 08:40:25 PM » |
I too, would like to see a SR-2A3. I have been thinking about what it would take to ramp up the 45 regulator. I was thinking of paralleled FETs or IXYS1045’s as the current source and using separate tubes for reg and signal duties.
My SR-45, scratch built with custom PS and MQ iron. Took on all comers at Hornfest.
Till the Dowdy Lama showed up with his mighty GM70 (we are not worthy)
Logged
John Scanlon
Bas Horneman
« Reply #6 on: October 30, 2009, 02:18:54 AM » |
Till the Dowdy Lama showed up with his mighty GM70 (we are not worthy Could you tell me more about the GM70? Kind regards, Bas
Logged
Len
« Reply #7 on: October 30, 2009, 01:12:36 PM » |
Kind regards, Bas
Amazing sound, when built by Jim. You need about a kilovolt for the HT, and the equivalent of an arc welder for the filaments. These amps normally weigh in at 80-100 lbs. I've been collecting parts for one for years. It's up in the 211 amp category, IMO.
Logged
Paramours Paraglows Excites Heavily modded Soul Sister and Groove Thang Quickie modded to active low pass filter Quickie modded to headphone amp Lots of Bottlehead parts used for building other stuff
Bas Horneman
« Reply #8 on: October 30, 2009, 01:20:58 PM » |
I've been collecting parts for one for years. Same here. Couple of months ago I bought the filament transformers....and this week some custom made teflon based sockets from ebay. Got parafeed transformers from MQ years ago.
Logged
Len
« Reply #9 on: October 30, 2009, 01:38:51 PM » |
Mine will probably be push-pull. Only because I have a nice pair of Jantzen electrostatic hybrid speakers here collecting dust, and they need at least 20 watts to come alive. 2a3's don't even trigger the circuit for the electrostatics sometimes.
Logged
2wo
« Reply #10 on: October 30, 2009, 08:45:00 PM » |
« Last Edit: October 30, 2009, 09:08:44 PM by 2wo »
Logged
John Scanlon
Bas Horneman
« Reply #11 on: November 02, 2009, 03:21:09 AM » |
Thanks 2wo!
Wish Dowdy Lama would put up a schematic. :) [EDIT] Oeps never mind. Found a description in one of the thread you posted. Essentially it is an 826 LC coupled to the GM70.
Kind regards, Bas
« Last Edit: November 02, 2009, 03:27:01 AM by Bas Horneman »
Logged
Len
« Reply #12 on: November 02, 2009, 04:30:15 AM » |
Hi Bas, I've read posts from Jim that hint at why he doesn't post schematics any more. It seems that when he did, some people would just throw the parts together and complain that it didn't sound good, etc. He believes in best practices for everything he builds, and it's not just the parts that make his designs work. It's one thing to build something sloppily at 400V, another at over a KV.
Logged
jrebman
« Reply #13 on: November 02, 2009, 04:40:27 AM » |
Actually, the B+ on this amp is only about 740 volts. Not child's play, but better than >1kv. And the amp weighs a mere 300 pounds.
Logged
Jim Rebman
Len
« Reply #14 on: November 02, 2009, 07:35:29 AM » |
I haven't looked at them lately, but I seem to remember that the lower voltage GM70 designs use more current than the "corona" versions. And don't forget, 300 lbs is a mere 150 lbs per channel. Almost as portable as the Quickie :-)
Logged
