Perhaps going to one bias string for the C4S boards would free up just enough? The FWB with choke input is a very good idea, isn't there a 7 or 9 pin 150v regulator?
Yes - 0A2, 7-pin. Max current is only 30mA, but the regulation spec is better than the 0D3. 0B2 at 105v is another possibility, if you have the C4S plate loads.
The dual bias strings on the Seduction C4S prevent a set of multiple wild voltage swings on start-up. Another lesson learned the hard way!
I took another look, and it looks pretty good. I think we can draw 30mADC from a fullwave bridge into an LC filter with 30 henries. That just happens to be the SEX amp plate choke value, and anyone who has upgraded a SEX amp probably has a couple of those lying idle.
