Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News
: Now taking orders for the Tode, Bottlehead's new guitar amp kit!
Calendar
Bottlehead Kits
Quickie
battery question for the quickie
Pages: [
Author
Topic: battery question for the quickie (Read 830 times)
balancedtriode
Newbie
Offline
June 20, 2010, 05:52:53 PM »
i was thinking and i couldnt think of any reason that why this would not work please correct me if i am wrong but lets say i had the battery in a box and wired to a terminal strip then wired them to a 6 pin mini DIN connector , then used a 6pin DIN Cable to another box with with a 6 pin DIN connector then wired to a terminal strip then wired to the other components would this work the 9v battery holders a wired in series so thats 2 leads 2D Cells so thats 4 more leads 6 lead total, so would this work? the mini DIN Cable inner wires are the same awg as the battery leads .
Logged
Revox B795 TT
Bottlehead Seduction
Bottlehead Stereomour
Klipsch Cornwalls' with Vertical Horns
Caucasian Blackplate
Hero Member
Offline
Re: battery question for the quickie
Reply #1 on:
June 20, 2010, 07:22:37 PM »
This is probably OK for the 9 volts, but maybe not so hot for the D-cells (wire losses, noise pickup, etc).
Logged
Grainger49
Hero Member
Offline
Audio Cheapskate
Reply #2 on:
June 21, 2010, 02:10:58 AM »
I would ask why would you want to do this? The batteries do not produce hum as an AC powered supply will. Maybe they are too ugly? Some folks have put the Quickie batteries below the top plate.
Logged
Grainger Morrison,
balancedtriode
Newbie
Offline
Reply #3 on:
June 21, 2010, 04:56:49 AM »
the reason i want to do this is is make a more portable quickie for headphone use ive managed to fit all the componets and transformers in to one pretty small box that will attach to my belt the tube sockets are mounted on the top of the box and use spring loaded tube guards for heat disipation and to protect the tubes a short 6 pin din cable will lead to a box in my backpack
Logged
Revox B795 TT
Grainger49
Hero Member
Offline
Audio Cheapskate
Reply #4 on:
June 21, 2010, 04:58:12 AM »
It would pull my pants off without a tight belt.
Thanks, I understand now.
Logged
Grainger Morrison,
Pages: [
Jump to:
Please select a destination:
General Category
=> Forum Rules
=> General Discussion
=> Bottlehead Special Deals
=> VALVE archive
=> Technical topics
=> Tech Tools
=> All things MagneQuest
=> Grainger's Corner
Bottlehead Kits
=> Gallery
=> Quickie
=> Crack
=> Smack
=> Foreplay III
=> Seduction
===> Seduction Tape Head Preamp
=> Eros Phono
=> Eros Tape
=> S.E.X. Kit
=> Stereomour
=> Paramount
=> Bottlehead Power Cord Kit
=> Technics Tape Path Kit
=> Tode
=> Legacy Products
Bottlehead Finished Products
=> Tube Phono
=> Tube Repro
Other Gear
=> Speakers
=> Headphones
=> Phono
=> Digital
=> Reel to Reel Tape
Loading...
