Will the BCP-15 and EXO 45 fit in the same space as the stock iron, and will the output power be significantly lower?
Anybody done this yet?
Jim
I have been running my S.E.X. amp this way for about three years. I wired the
EXO 45 as an autoformer per PJ's advice. Most of the time I used it with Lowthers
having 15 ohm specs, so the reflected impedence was close to the design spec
for the amp. Still sounds good on 8 ohm speakers. In that case, the power should
be slightly higher than stock and the same for the distortion, if I understand
correctly.
Skip
