Pages: [1]   Go Down
Author Topic: Could the Stereomour run the Straight 8?  (Read 767 times)
Todd R
Jr. Member
Offline Offline
View Profile
« on: July 03, 2010, 03:27:48 PM »
I have a friend with a pair of Straight 8's that I might talk her out of, but will 3.6w do the trick? Couldn't find any specs on the speaker.
TIA
Logged
Grainger49
Hero Member
Offline Offline
Audio Cheapskate
View Profile
« Reply #1 on: July 03, 2010, 05:08:03 PM »
When I started on the old site the Straight 8s were available the standard amplifier was a Paramour.  There were probably other previous 300B amps but the 3.5 WPC of a 2A3 was fine.
« Last Edit: July 06, 2010, 02:27:10 AM by Grainger49 » Logged
Grainger Morrison,
jrebman
Hero Member
Offline Offline
Blind Bottlehead
View Profile
« Reply #2 on: July 04, 2010, 07:43:49 AM »
Todd,
If I'm remembering correctly, the S-8s were something like 98 dB sensitive which should really rock with the 2a3 Stereomour, no problem.  45s will also go quite a long way too, and depending on room size, musical tastes, etc., should also be fine.  Of course I have no idea what the impedance and phase curves look like, but we'll assume it is a SET-friendly design considering where it comes from.
HTH,
Jim
Logged
Jim Rebman
Alix linux box --> HRT MusicStreamer II+ --> Crack --> Sennheiser HD-600s.
Doc B.
Administrator
Hero Member
Offline Offline
View Profile WWW
« Reply #3 on: July 04, 2010, 11:25:55 AM »
96dB
Logged
Hero Member
Offline Offline
View Profile
« Reply #4 on: July 05, 2010, 07:52:18 PM »
My recollection is that the 3.5W original Paramour was adequate for the Straight-8s but an 8-watt 300B amp (Parabee at that time) was an improvement in larger rooms. The original Paramour did not have a 16-ohm output tap, so it was used with an 8 ohm tap; I would guess around 2.5 watts output. The Stereomour has a 16 ohm tap and can make a full 3.5 watts into 16 ohms. The various stock Paramours (I and II) had some power limitations below about 80Hz, and the Stereomour does much better in that respect. So the combination should be audibly better than an older Paramour.
Logged
Pages: [1]   Go Up
Jump to:
