Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News
: Now taking orders for the Tode, Bottlehead's new guitar amp kit!
Calendar
Bottlehead Kits
Foreplay III
Left channel is not at the same level as the right channel ????
Pages: [
Author
Topic: Left channel is not at the same level as the right channel ???? (Read 616 times)
audiblesoundwave
Newbie
Offline
August 09, 2010, 04:45:37 PM »
Hi everyone,
Lately, my left channel on the FPIII is not as loud as the right channel! I spent a couple of weeks on isolating the cause. I swapped cables, different side of the amps (are mono amps), swapped tubes on the FPIII; finally, my conclusion is something may be not working properly on the left side of my FPIII. The high seems to be cut off quite a bit. I feel the volume is reduced 2-3 clicks, 3-6db (I am guessing) :-)
I am planning to dust off my manual and start to check out the resistance and voltage of the soldering points this coming weekend. However, I decided to check with the forum to see any advises where to start first on finding the problem.
Any inputs?
Milton
Logged
JC
Sr. Member
Offline
Re: Left channel is not at the same level as the right channel ????
Reply #1 on:
August 09, 2010, 05:05:37 PM »
To be perfectly honest, it sounds as if you are already headed down the path I would take. If the various swappings you have tried resulted in the issue staying on the same channel, then comparing the resistance and Voltage measurements between the two channels and against the manual seems like exactly the right "next step".
Going over the signal path from input to output on the side with issues, looking for suspicious solder joints, might also be of use; I always recommend a good light and a magnifier, since my eyes are getting older! In my experience, a flaky solder joint can easily account for 3dB.
Good luck with your hunt!
Logged
Jim C.
Pages: [
Jump to:
Please select a destination:
General Category
=> Forum Rules
=> General Discussion
=> Bottlehead Special Deals
=> VALVE archive
=> Technical topics
=> Tech Tools
=> All things MagneQuest
=> Grainger's Corner
Bottlehead Kits
=> Gallery
=> Quickie
=> Crack
=> Smack
=> Foreplay III
=> Seduction
===> Seduction Tape Head Preamp
=> Eros Phono
=> Eros Tape
=> S.E.X. Kit
=> Stereomour
=> Paramount
=> Bottlehead Power Cord Kit
=> Technics Tape Path Kit
=> Tode
=> Legacy Products
Bottlehead Finished Products
=> Tube Phono
=> Tube Repro
Other Gear
=> Speakers
=> Headphones
=> Phono
=> Digital
=> Reel to Reel Tape
Loading...
